It is currently Sat Aug 02, 2025 6:33 pm
 Post subject: Minimum length
PostPosted: Sat Apr 06, 2019 10:00 pm
First name: Ken
Last Name: Hageman
City: Statesville
Zip/Postal Code: 28625
Greetings, What is the minimum length of side plates for a dreadnought guitar? I have a chance to get a great set of Cocobolo, but the side length is 30 3/4 inches. To small? Thanks in advance for the help. Ken
 Post subject: Re: Minimum length
PostPosted: Sat Apr 06, 2019 10:28 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Take a tape measure to a dreadnought and see. My limited experience says, for me, I want two inches more than the finished length. Too easy for me to shift a side in the bender and seriously hope for enough excess built into the side material to allow for the miscalculation.
Peter Havriluk
First name: peter
Last Name: havriluk
City: granby
State: ct
Peter Havriluk
PostPosted: Sat Apr 06, 2019 10:30 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
I get 30.5 on my template, so that leaves virtually nothing for trimming.
You can compensate with the end graft and situating the heel. You may need to glue in the blocks without the sides touching at the graft.
Or make slightly smaller dread or other model.
B
PostPosted: Sun Apr 07, 2019 5:35 am
this can make it but to know for sure be careful as you bend and you can always use a piece at the tail and neck block to add. A nice tail wedge can give you a 1/2 in and at the neck block you can rob another 5/8 in
backs are 20 in long and 15 1/2 wide
PostPosted: Sun Apr 07, 2019 6:00 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I recently put the equivalent of a tail wedge at the neck end, just to do it and see how it looked. If you combine that with a wider than normal tail wedge, you can definitely make these sides work.
PostPosted: Sun Apr 07, 2019 6:37 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
If using a block-style heel and the aforementioned wider end graft, the sides might be as much as 1-1/4" shorter than the center-line to center-line length of whatever body template you might employ, although this reduced-length side also puts a premium on eliminating any error in positioning the ends associated with the side bending process.
- Beth Brower
PostPosted: Sun Apr 07, 2019 9:27 am
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
You could also use a piece of an off-cut from the back , same material as the sides and run the grain horizontal for a tail graft, using 2 strips of bwb purfling on each side, to make it appear like there is no tail graft.
Users browsing this forum: G.Cummins and 17 guests
